Control Help - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2009, 06:16 PM   #1
control help
hi.i have a luxaire HL5B series 2stage cooling heatpump with c,y1,y2,o,w,x/l,r,y2out,w2out,w1out wires and a gas furnace with r,w,c,y,g wires my question is can I just install a 2stage cooling heating tstat or do I need a control board ? any help would be great ,Thanks.
dat201 is offline   Reply With Quote
Old 06-01-2009, 08:28 PM   #2
An old Tradesmen
Rewards Points: 6,860
A 2 stage HP thermostat will work.
The defrost board is a dual fuel control.
But you won't get the performance out of that 2 stage heat pump that you should. With that single stage PSC blower furnace.
It won't have the humidity control in first stage that it would with a VS blower.
Old 06-01-2009, 08:36 PM   #3
Yes, you can but, the little extra you will pay for the extra stage will be returned to you in lower operational costs and comfort.
dac122 is offline   Reply With Quote
Old 06-01-2009, 08:45 PM   #4
An old Tradesmen
No idea how you figure that.
His furnace doesn't the ability to slow down to remove moisture in first stage.
So he won't get the comfort increase from it that you speak of.
Old 06-02-2009, 08:46 AM   #5
thanks for the answers.i know it's not the best furnace, for now it,s all i have.I will probably be checking on wiring it since its been over 10 years since i installed an heatpump.Thanks
Old 06-03-2009, 10:56 AM   #6
Ok ,how would you wire The thermostat?
Old 06-03-2009, 11:13 AM   #7
Please provide make and model of thermostat
Old 06-03-2009, 11:23 AM   #8
An old Tradesmen
Stat R to furnace and HP R.
Stat C to furnace and HP C.
Stat G to furnace G.
Stat Y1 to to furnace Y and HP Y1.
Stat Y2 to HP Y2.
Stat W1 or W2(depending on thermostat) to HP W
Stat O to HP O.
HP W1 out to furnace W.
Stat X/L to HP X/L.
Then set the heat pumps defrost board to dual duel control. And set its balance point, Y2 lock, and switch over temps.
He could also install a relay to slow the blower to its lowest speed when the heat pump is in first stage heat or cooling.
But most PSC blowers won't slow enough to make a difference.
He could add a ICM or Fan Handler control, and set it up for discharge temps.
But it won't work as good as a VS blower would.
And it can't take advantage of the HP's hot heat pump feature.
Old 06-03-2009, 11:24 AM   #9
An old Tradesmen
He'd be better off with a single stage heat pump.
Old 06-03-2009, 12:46 PM   #10
Thank you very much,you've been very helpful.
Old 06-03-2009, 01:57 PM   #11
An old Tradesmen
Your welcome.
But seriously.
You won't get the comfort that heat pump is suppose to give you.
When you use it with a standard blower furnace.
Old 06-04-2009, 11:15 AM   #12
thanks that will be the next project
tapping into well control box? jjkrem Electrical 6 02-01-2009 11:03 AM
Well pump control box delema freeonthree Electrical 36 11-02-2008 09:55 AM
control 4 switches gooch Electrical 3 01-03-2008 08:05 PM
