Control Board? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 05:34 PM   #1
control board?
Trying to figure out if the control board is bad. inducer fan and blower fan run all the time even when i disconnect t wires at board even if i pull the plug harness with wires that go to gas valve,inducer switch and limits.Sounds like a bad board everything else checks out oh my voltage at the w on t stat is only 17v all others are 24?
dub2dub is offline   Reply With Quote
Old 02-15-2010, 07:09 PM   #2
Is it a ComfortMaker furnace? Many furnaces will energize the blower and inducer motors if you have an open limit. Check for continuity through all the limits before you pull the board.
brandonmcginnis is offline   Reply With Quote
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
How do you ground York furnance control board garryshaf HVAC 11 01-24-2010 12:06 PM
Goodman 4 flashes on control board bigmac71201 HVAC 6 09-28-2009 02:53 PM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
