Contactor Wiring/Terminal Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2010, 06:03 PM   #1
I'm replacing the single pole contactor on my unit (decided to DIY since $604 for $50 worth of parts seemed ridiculous). My problem is that the replacement contactor has two terminals identical to the old one but two that are different - I need help with hooking up the wires to the terminals that are different.
My old one has four screws and all 4 of the wires have the circular endloops so the screw goes inside of them.
The new contactor has two screws on top and two boxes that you have to insert wires into then secure with a screw. What do I need to do to the wires, if anything, to prepare them for inserting into these screwed holes since there isn't a way to hook the loops on a screw end?
This is what the current one looks like:
http://www.triiac.com/Contactor%20Single%20Pole.jpg
and two of the ends on the replacement looks like the ones shown here:
http://www.arnoldservice.com/45eg10ajaL1all.JPG
Any help with how to modify the wires (or if I just need to clip off the loops and stick in in) would be great!
Thanks in advance.
ninetyfeet is offline   Reply With Quote
Old 07-08-2010, 06:26 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,798
Those are wire connectors with a set screw and can be used for stranded or solid wire. Cut off the circular loops and carefully strip the wires with a proper wire stripper so you don't lose any strands or nick the wire. Leave enough wire for the set screw to attach to and tighten well.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
