Originally Posted by beenthere
The low voltage looks right.
Hard to tell for sure on the contactor. Since I can't see what wires you have under the black and white.
As i look at it. It almost seems your missing a wire from the contactor to the capacitor.
On my old contactor/capacitor I only had three wires connected to my capacitor and only one of them connected to the contactor.
Under the black and white wires are a red wire that goes down into the unit and the wire that connects to the capacitor.
OK. You had me worried there.
You need to use that meter. And check the low voltage wires for shorts to ground, or to other wires.
The voltage outside looks good, but the big thing I'm trying to figure out is why my gas furnace/fan isn't working now.
I turned the power to the outside unit off and then went inside and unplugged the gas furnace as directed by the HVAC tech that came out.
When I was done wiring the contactor/capacitor I went inside and plugged the furnace back in and then went outside and turned the power on the outside unit to on.
Ever since I unplugged the furnace it hasn't come back on.
Is it possible that my transformer blew? If so how do I check and would that cause my furnace circuit board to not light up?
