Contactor Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 10:10 AM   #16
Thanks guys I will remove the board and see if one of the gurus in town will have a look at it.
kokerot is offline   Reply With Quote
Old 02-26-2012, 11:27 AM   #17
biggles's Avatar
if the air handler end has a transformer within then the compressor contactor COIL voltage is 24Vs if you push it in and it runs that winding in the compressor is Ok electrically...freon working wise is the mystery? it being a Heatpump the compressor call is common on heating or cooling the stat swings the reversing valve.check here for boards http://bestbuyheatingandaircondition...cuitboards.htm
Old 02-26-2012, 11:31 AM   #18
Originally Posted by kokerot View Post
At Jackofall1
You see I learn something everyday, I really thought that the relay was a contactor
A 'contactor' seems to mean 'a heavy duty relay'.
Old 02-26-2012, 11:35 AM   #19
Experienced
Jackofall1's Avatar
Yes but that looks like a 4-pole controls relay, which will not have the capability of handling the amperage draw of a compresser. Typical contact capacity is 5-8 amps for a relay of that style.
Mark
