#16 |
contact continuity tester
I read it's description...It's like plugging a lamp...if the lamp lights you have voltage and inherently MUST have continuity...but it's still a lamp, not a continuity tester...and either is this Morris device.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#17 | |
Part of the Clover Leaf
contact continuity testerQuote:
You grab the contact point in one hand and the fuse in the other hand...touch the tip to the fuse as you hold it...circuit is completed thru your body. Good fuse the light glows...bad fuse...no glow. These things were as common as as gauge sets about five years ago. I just ordered two. Last edited by hvac5646; 12-21-2012 at 03:33 PM. |
| The Following User Says Thank You to hvac5646 For This Useful Post: | Missouri Bound (12-21-2012) |
| Display Modes | |
| Need advice on whats the best non contact voltage tester | humberguy | Electrical | 16 | 12-31-2011 03:37 AM |
| Buying an electrical outlet costing .99 cents vs. $3.00 | Mikon8er | Electrical | 40 | 11-20-2011 12:01 PM |
| continuity tester | drewhart | Electrical | 11 | 12-11-2008 05:06 PM |
