Contact Continuity Tester - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 10:16 AM   #1
contact continuity tester
who makes or sells them?
Merry Christmas
and thanks
Clover
hvaclover is offline   Reply With Quote
Old 12-21-2012, 10:21 AM   #2
Missouri Bound's Avatar
Nobody. Continuity can't be detected that way. Are you referring to contact voltage detectors?
Do you want it your way or the right way?
Old 12-21-2012, 10:21 AM   #3
Rewards Points: 13,694
There's hundreds of companys that make them, any box store, electrical supply, on line on sites like Amazon, ebay and hundreds of others sell them.
Might want to share what you plan to use it for to narrow it down.
Old 12-21-2012, 11:04 AM   #4
CONTACT contiinuity testers?
Old 12-21-2012, 11:28 AM   #5
Roofmaster
Rewards Points: 2,210
WHa iddit?
Old 12-21-2012, 12:19 PM   #6
Arghh...I feel like a rookie for asking this...but I appreciate the help.
What am talking about is an probe that looks like a voltage detector, pocket size and pretty much the same "fat pencil" shape of a voltage detector.
What I am talking about measures the continuity thru fuses (or circuits).
You hold the end conductor in one hand and touch the probe tip to the end of a cartridge fuse you hold in your other hand. Detector LED lights op if fuse is ok...no light if fuse is open.
I checked all over Google, and unless (I am not using the right Key Words) and got only voltage detectors.
Thanks again guys.
Clover.
Old 12-21-2012, 12:25 PM   #7
Any continuity tester would work for fuses...you just have to remove them from the circuit first.
Old 12-21-2012, 12:37 PM   #8
Too true... but with this probe you don't have to use a meter....just pull the fuses and put the probe to the fuse.
Am I getting what U are saying or am I missing something?
Old 12-21-2012, 12:51 PM   #9
Well...in order for a continuity check on fuses you need to be in contact with each end. A device with a probe and a wire will work. I wasn't suggesting a meter. The simplest type is much like a screwdriver with a wire attached, and a lamp inside. If you have continuity the lamp lights when you get a circuit across the wire and the probe. These types are often used in tracing automotive wiring. Whatever you choose will have a battery to facilitate the continuity notification, whether it be a lamp or a noise of some sort.
Old 12-21-2012, 12:52 PM   #10
Klein Tools -Continuity Tester
Will any of these work?
Old 12-21-2012, 01:08 PM   #11
Thanks for the links...bur the one I refer to has no test leads....it's a pen size instrument...
Old 12-21-2012, 01:11 PM   #12
That cannot work...continuity can NOT be read from just one point.
Old 12-21-2012, 01:43 PM   #13
Hvac5646 suggested some different Key-Words for a Google search...(damn, getting old lol)
Found it ...it's a Morris 59059
Thanks every one ...
Merry Christmas
Old 12-21-2012, 01:55 PM   #14
bbo
weird, how can one check continuity from only one point?
bbo is offline   Reply With Quote
Old 12-21-2012, 01:56 PM   #15
As I said earlier...you cannot check continuity from one point.
Need advice on whats the best non contact voltage tester humberguy Electrical 16 12-31-2011 02:37 AM
Buying an electrical outlet costing .99 cents vs. $3.00 Mikon8er Electrical 40 11-20-2011 11:01 AM
continuity tester drewhart Electrical 11 12-11-2008 04:06 PM
