Contacor Button - HVAC - DIY Chatroom Home Improvement Forum
Old 06-11-2008, 02:55 PM   #1
jw1
Contacor button
Hello, anyone know what the button on the center of my contactor is for?
SIEMENS 3100-30Q1028XT HN52PD024
FLA 50 Amp Res per pole.
jw1 is offline   Reply With Quote
Old 06-11-2008, 03:02 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it isn't really a button per se but is a point which you can press to manually engage the contactor.
Old 06-11-2008, 03:09 PM   #3
jw1
Could this be why the pc board is flashing contactor fault?
I inspected the contactor and everything looks fine.
Old 06-11-2008, 09:09 PM   #4
Looks can be deceiving. If you are getting 24 volts to the contactor coil and it is not pulling in, then you need to replace it.
cjett is offline   Reply With Quote
Old 06-11-2008, 09:32 PM   #5
jw1
It is pulling in.
All the connections appear to be fine.
Any ideas what it might be?
Old 06-12-2008, 07:10 AM   #6
nap
You talking to me?
nap's Avatar
do you have a voltmeter
Old 06-12-2008, 09:20 AM   #7
If it is pulling in, what is not working? If the fan is coming on but not the compressor, it might be a wire off at the compressor.
Give us more info.
Old 06-12-2008, 10:15 AM   #8
jw1
Yes I have a volt meter. When I replaced my outdoor fan units motor I applied power to the unit and everything ran find Except the PC board was flashing 73 which refer to a contactor fault. I turned off the power to the AC unit and inspected the contactor as advised. The contactor appears to be brand new. The contactor also pulls in when power is applied. So I re-applied power to the unit and now the fan won’t spin but shutters or vibrates and I turned off the power again thinking I might damage the new motor.
Old 06-12-2008, 05:15 PM   #9
jw1
OK, It’s Working!!! Finally, one small wire out of place that needed to be on the bottom of the contactor rather than the top! So much for my ability at reading blueprints. Now everything runs fine! However, the board still flashes contactor fault. I had a tech check the contactor and he said everything is fine and in working order and not to change it until it goes out completely.
Is an electrics reset switch somewhere on the board used to clear the fault?
