Consolidated Industries Model MBA - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 09:21 AM   #1
I have a Consolidated Industries Model MBA furnace that runs for a short time and shutts off. I have replaced the tstat, smart valve, flame sense and control board and it still does the same thing. I also have checked the limt switchs they all have 27.4 volts going though them and also have 27.4 volts a w on the board hope some one can help me with this
DWAGNER is offline   Reply With Quote
Old 12-13-2009, 09:56 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
Did you check across the pressure switch to see if it is opening. If it does you will get 24 volts, 0 when closed. Check your venting for obstructions and post some pics of the furnace with both doors off, or a video on youtube and link here.
Old 12-13-2009, 10:54 AM   #3
yes I did check the presure sswitch it also has 27.4 volts when colsed. I have also checked the vents I cant see any thing blocking theair flow. I will work on getting some pics on
Old 12-13-2009, 10:59 AM   #4
Hvac Pro
yuri's Avatar
Should have 0 volts ACROSS it, 2 terminals when closed and 24 volts ACROSS it when opened.
Old 12-15-2009, 09:31 PM   #5
thanks I tested the presure switch and found I am not getting vacuum to hold it open. Can it be a cracked heat exchanger?
Old 12-15-2009, 09:55 PM   #6
Hvac Pro
yuri's Avatar
Do you have a manometer to check the "WC suction on it? Try poke thru the hole on the spud of the ventor fan NOT the pressure switch itself. Where the tube attaches to the fan it can plug that port with deposits. Use a small drill bit ideally or a paper clip if nothing else available. Check the condition of the tube for cracks. Post some pics of the furnace with both doors off. Not a unit I see in my area but our other techs may recognize it.
Old 12-16-2009, 06:30 AM   #7
An old Tradesmen
Rewards Points: 6,550
Follow Yuri's advise.
You could have a cracked heat exchanger. So inspection of it is never a bad idea.
Are Metal Industries Windows Good? jelly Building & Construction 8 11-20-2013 12:31 PM
Need help on a York Model # Wicky611 HVAC 1 08-06-2008 11:08 AM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 08:04 PM
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 04:24 PM
