Consolidated Home AC/Heater Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 06:40 PM   #1
I have a Consolidated home furnace installed 1997, model ST9141B1001, and the a/c blower works and then shuts off, apparently of overheating. I was told the blower is obsolete and finding a new motor unlikely. A new furnace was suggested at $2300. Can some other blower motor be used or is there a place that sells old Con. motors, since Cosold. is out of business? It seems crazy and expensive to replace the whole unit for a motor.
omtyp is offline   Reply With Quote
Old 07-19-2011, 07:13 PM   #2
JJboy's Avatar
You can use standard motor. You need all the specs:
RPM
Voltage
HP:
Amp
Frame:
etc
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Help with HVAC blower motor wiring Jcpilot Electrical 4 03-18-2012 02:28 PM
Should I replace the blower motor too? Arthas HVAC 4 05-06-2011 08:43 PM
New AC/furnace blower motor will not turn off Larry2010 HVAC 0 06-08-2010 08:46 PM
comfortmaker furnace; i've done the hard part by taking the blower motor out Hurell HVAC 2 06-05-2010 01:03 PM
blower motor cycles on and off very often only in A/C mode carrara HVAC 8 06-28-2009 09:51 PM
