#1 |
Considering a conversion from FL Heat Pump to AC
I have a heat pump AC that is about 13 Seer that is 3 ton. I am considering replacing it but is it a lot more work to put the blower in and the condensor outside? The last guy said stick to replacing the heat pump.
Thanks. Frank Lardino |
#2 |
An old Tradesmen
Are you referring to changing to a split system. from a packaged unit.
#3 | |
Considering a conversion from FL Heat Pump to ACQuote:
Frank Lardino |
#4 |
An old Tradesmen
Ok. You don't have an outdoor unit with this heat pump.
Is yours a water source heat pump? |
#5 |
Considering a conversion from FL Heat Pump to AC |
| Display Modes | |
| Heat pump and Honeywell 8000 questions. | jyoderz | HVAC | 14 | 04-06-2010 03:26 PM |
| Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) | pomelo | HVAC | 11 | 03-08-2010 09:13 PM |
| New Install - Heat Pump Woes... | mark1210 | HVAC | 7 | 03-07-2010 10:14 AM |
| Comparison and Heat Pump Selection help... | ChrisDIY | HVAC | 7 | 03-06-2010 09:34 PM |
| Brand new Carrier Infinity 16 Heat Pump Stopped Working I think | needmyac | HVAC | 3 | 07-07-2009 07:12 PM |
