-   -   Considering a conversion from FL Heat Pump to AC (http://www.diychatroom.com/f17/considering-conversion-fl-heat-pump-ac-73277/)
FrankL 06-09-2010 05:49 PM
I have a heat pump AC that is about 13 Seer that is 3 ton. I am considering replacing it but is it a lot more work to put the blower in and the condensor outside? The last guy said stick to replacing the heat pump.
Thanks.
Frank Lardino
beenthere 06-09-2010 06:00 PM
Are you referring to changing to a split system. from a packaged unit.
FrankL 06-09-2010 06:07 PM
The current heat pump is on a stand in the garage and blows into the house. I think with a standard AC unit I would need the blower in the same place and a condensor outside? The AC discouraged me from changing cause it is "a lot of work." Thanks.
Frank Lardino
beenthere 06-09-2010 06:17 PM
Ok. You don't have an outdoor unit with this heat pump.
Is yours a water source heat pump?
FrankL 06-09-2010 06:25 PM
Ground water with discharge into a canal.
beenthere 06-09-2010 06:27 PM
Ok.
Yep. You'll need to install an outdoor unit. If you want to get away from a water sourced unit.
