Connecting Semi-rigid Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 05:36 PM   #1
Just a DIY guy
Connecting semi-rigid duct
My 30-year-old house HVAC is put together with semi-rigid duct in the attic.
http://www.homedepot.com/buy/applian...uct-64218.html
It is insulated with fiberglass sleeves, most of which is covered in grey vapor barrier.
They used cloth "duct tape," some of which is holding on, but a lot is not. I'm trying to refurbish the system by sealing it all properly. I've done just a couple, but I'm not sure I'm doing it right.
Where the hard metal connector fits into the semi-rigid, I'm using sheet metal screws with washers to secure the semi-rigid to the hard metal connector, then using both mastic and foil tape. (btw, the "mastic" they sell at HD (Masterflow) seems awfully thin compared to what I've seen on home improvement shows on TV, which looks more like toothpaste).
But where the semi-rigid fits into the metal connector, they simply cut a slit in the end, folded the semi-rigid into a slight cone, and stuck it in there. Usually the "duct tape" is not even covering the slit, and they leak like crazy.
What is the proper way to make these connections?
Can you use a crimper on semi-rigid? Is there any way to make a mechanical connection? Or do I have to rely on loads of foil tape? Or do you use a metal connector so that the semi-rigid goes around the outside of the connector, regardless of flow direction?
I know the best answer is probably to replace the semi-rigid, but I have an awful lot to do. But if that is your answer, can you give me advice as to what is easier for a homeowner to use, flex, sheet metal, or something else?
M3 Pete is offline   Reply With Quote
Old 12-19-2011, 06:25 PM   #2
Houston204's Avatar
Rewards Points: 556
I have never seen that used for anything other than a bathroom exhaust venting.
I'd go back with flex or pay someone to install rigid round pipe.
Houston204 is offline   Reply With Quote
Old 12-19-2011, 06:47 PM   #3
Ditto.Never seen it used for supply air,only the first few feet of a drier vent. Hard pipe with an insulated sleeve or insulated flex should be what's used in an attic.
Old 12-19-2011, 07:05 PM   #4
Just a DIY guy
guys, the link I posted is for 7" duct. Clearly that's not dryer venting. Unless that's an awfully big dryer.
They make it in sizes from 3" all the way up to 16"
http://www.deflecto.com/advp/product...&idCategory=57
It is all insulated with sleeves.
Old 12-19-2011, 07:06 PM   #5
biggles's Avatar
if that is a cold attic in the winter your heat is going to cool off trying to get to the rooms and not at all the right stuff...and there are take offs that install with the direction of the air.... http://www.bestbuyheatingandaircondi...e=duct-collars
Old 12-19-2011, 07:32 PM   #6
Just a DIY guy
As I mentioned, it's all insulated.
So far, the take-offs (start collars) are not the issue, it's the Tee Wye's and registers, with ends that take a crimped pipe.
Even the supplier you linked has the semi-rigid for sale, up to 18"
http://www.bestbuyheatingandaircondi..._Code=duct-mfd
Old 12-19-2011, 07:46 PM   #7
as seen on tv
Rewards Points: 150
You may need to crimp the hard pipe end and seal with some good ul foil tape. It will be a crappy seal any way you do it. Insulated r.8 insulated flex of the proper size would be the way to go
qbert is offline   Reply With Quote
Old 12-20-2011, 02:35 PM   #8
Just a DIY guy
Thanks qbert. I was thinking of using these duct couplings, which will allow me to make a mechanical connection (screws and washers) with the semi rigid on both sides.
http://www.bestbuyheatingandaircondi...uct-connectors
Not the best way, but the mechanical connection would at least allow me to mastic and tape the joint with confidence it won't come apart (or leak).
I'm using Scotch 3311, is that "good UL foil tape?"
http://www.shop3m.com/3m-scotch-foil...vp7k7wz70.html
Old 12-20-2011, 05:02 PM   #9
An old Tradesmen
Rewards Points: 7,414
Pic looked like flex duct. Code limits it to 14' I believe. Best not to use it for supply runs other then in tight spaces, or for elimination of vibration, its very restrictive to air flow.
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Rigid Duct Insulation Alternative Earnie HVAC 6 01-13-2010 09:06 PM
Connecting 3.25 x 10' rectangular duct radzguy HVAC 1 03-03-2009 05:46 AM
Connecting inline duct fan to furnace dlem HVAC 1 02-11-2008 05:50 PM
