Connecting Final Ridgid Ductwork - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 12:42 PM   #1
Connecting final ridgid ductwork
Hi all,
I was originally planning to use a semi-ridgid aluminum duct between my kitchen exhaust elbow and microwave transition, but I am trying to maintain a fully ridgid design (possibly 2 elbows and a short straight). The problem I would have is installing the final piece since there is roughly 1-2 inches of extra length to account for the male/female overlap. I may have backed myself into a corner on this one, but can anyone think of a technique or solution that would allow me to connect the two male ends (shown in picture) using ridgid pieces?
Connecting final ridgid ductwork-img_2372.jpg   Connecting final ridgid ductwork-img_2373.jpg
bee-man is offline   Reply With Quote
Old 03-16-2013, 01:21 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
there are a couple of methods.
1) not sure where you can buy them but a sheet metal shop may have them or check HDepot etc. you can buy a "slip collar" piece of pipe which closes together with 2 gear clamps or thin bolts. you open it and wrap it around the joint of the 2 pieces of pipe like wrapping a sheet of paper around the joint. then it has 2 gear clamps or a metal edge with 2 1/8" bolts to join the pieces together/ kinda like buying a plumbing MJ clamp and slitting the rubber folding it over and using the gear clamps to finish it ( obviously you need a 7" in that scenario ).
2) tin basher trick is to take a piece of 7" or 8" pipe and wrap it around the 6" after cutting off the press together joint, and if it was me I would pop rivet it over top of the 6" and seal the joint with metal foil tape. you can use screws but they may rust and aluminum pop rivets won't.
Old 03-16-2013, 03:11 PM   #3
Roofmaster
Rewards Points: 2,172
The bottom is a female, not a male, so whats the problem? Just use two els which are adjustable by twisting segments, and cut the straight portion to length prior to locking it. You sure lost use of that cabinet, couldn't you put rectangular ductwork in the wall with rear exhaust ????
Old 03-23-2013, 01:23 PM   #4
Thanks for the response. Here is what I have so far with my semi-rigid connection secured with 6" stainless steel clamps... didn't turn out as bad as I thought.
Jagans, I only assumed the transition was male because I was not able to fit my semi-ridgid (or even a ridgid) inside. But what is this "els" you speaketh of? I like the concept, but my searches turned up empty, probably because I do not know the technical name or nomenclature. I butchered this cabinet because the washroom is on the other side and recirculate was not an option. I do think there is still usable space for my cereals and even a little more after I put a shelf on the right side
Connecting final ridgid ductwork-img_2374.jpg   Connecting final ridgid ductwork-img_2375.jpg
Old 03-23-2013, 04:11 PM   #5
sktn77a's Avatar
Rewards Points: 392
That looks pretty good to me. It might not be optimal for a dryer vent but for a kitchen vent should be fine. One curved semi flexible section is probably as good (or better) that a rigid pipe with hard bends.
sktn77a is offline   Reply With Quote
A/C and Ductwork Efficiency Jessidog HVAC 1 07-29-2011 08:48 PM
Ductwork Insulation tk3000 HVAC 3 11-19-2010 05:08 PM
Final Inspection Questions docmattman Building & Construction 6 07-15-2010 08:11 PM
plastic ductwork vs. metal: acoustic duct liners jjpclev HVAC 5 02-26-2010 08:29 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 04:11 PM
