Old 03-12-2007, 07:43 AM   #1
Connect metal duct to flex?
I need to move a register over about two feet (entryway floor re-layout). The duct is currently run in metal. Is it possible to just add a 2 foot piece of flexible ducting onto the end of the metal run(after removing end piece) and then attach the end onto the flex?
Or would it be easier to just redo the entire run (about 10 feet) in flex?
THanks!
tigerbalm2424 is offline   Reply With Quote
Old 03-12-2007, 09:14 AM   #2
Well, they sell flex in 25 ft lengths, they sell hard pipe in 2,3,and 5 ft lengths.........if you already have the flex laying around, then yes you can just add it .
harleyrider is offline   Reply With Quote
Old 03-12-2007, 09:20 AM   #3
Thanks. Any special way to connect flex to hard? Specific clamp or such?
Old 03-12-2007, 03:30 PM   #4
Large band clamps, ties wraps and/or mastic. Tighten them well and make sure the flex run is well supported. (ie no sag where it connects to the metal).
Tape the outer layer of the flex but don't use regular duct tape. Duct tape isn't for ducts!!
I'd use metal if I were you.
hennyh is offline   Reply With Quote
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 02:12 PM
