-   -   Connect metal duct to flex? (http://www.diychatroom.com/f17/connect-metal-duct-flex-7057/)
tigerbalm2424 03-12-2007 06:43 AM
I need to move a register over about two feet (entryway floor re-layout). The duct is currently run in metal. Is it possible to just add a 2 foot piece of flexible ducting onto the end of the metal run(after removing end piece) and then attach the end onto the flex? :huh:
Or would it be easier to just redo the entire run (about 10 feet) in flex?
THanks!
harleyrider 03-12-2007 08:14 AM
Well, they sell flex in 25 ft lengths, they sell hard pipe in 2,3,and 5 ft lengths.........if you already have the flex laying around, then yes you can just add it .
tigerbalm2424 03-12-2007 08:20 AM
Thanks.:thumbsup: Any special way to connect flex to hard? Specific clamp or such?
hennyh 03-12-2007 02:30 PM
Large band clamps, ties wraps and/or mastic. Tighten them well and make sure the flex run is well supported. (ie no sag where it connects to the metal).
Tape the outer layer of the flex but don't use regular duct tape. Duct tape isn't for ducts!!
I'd use metal if I were you.
