Connect Desert Spring Humidifier To Carrier Infinity 96 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 02:07 PM   #1
Connect Desert spring humidifier to carrier infinity 96
Hi
I just had a carrier infinity 96 installed with the infinity control thermostat. I would like to install a desert spring rotating disc humidifier to this system and have the infinity control govern the humidifier (as well as the furnace). Can some please tell me how the wiring should be done so that I don't fry the furnace's control board or burn the humidifier's motor.
thanks so much
lshulster is offline   Reply With Quote
Old 12-07-2010, 04:30 PM   #2
The humidifier will be wired to "hum" and "c" on the furnace control board, and will automatically engage during a call for heat. Consult the Infinity Controller installation manual for more specifics, but this is the gist of it.
hvac benny is offline   Reply With Quote
Old 12-07-2010, 04:56 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
it really needs a relay and separate transformer to run a humidifier, don't take 24v from board if something goes wrong then this setup would protect board, also don't use that Hum. anything with a reservoir is not a good humidifier. it will only grow stuff no mater if its being flushed or not. get a flow through, duct mounted humidifier I use aprilaire. Honeywell is basic same design as well
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-08-2010, 01:24 AM   #4
Lightbulb
Yikes! I guess I'll leave any humidifier questions alone from now on. Being from Vancouver, humidifiers aren't really used here, as moist air is something we have in abundant supply . Thanks for the eye opener tech126!
Old 12-08-2010, 05:10 AM   #5
An old Tradesmen
Rewards Points: 7,816
Get a good humidifier. A flow thru. Less chance of mold problems. And usually, less maintainence.
Old 12-10-2010, 10:27 AM   #6
thanks
Thanks for the information.
I'll try to locate the DPST relay by calling a local HVAC part distributor.
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 05:33 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 08:30 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 04:20 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
