Confortmaker Furnace Model # FBF100F14G1 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 11:18 AM   #1
confortmaker furnace model # FBF100F14G1
Hello....Inducer motor & blower run all the time with no heat...at the thermostat I try to adjust & turn off & I get nothing....so i turn off the main switch by the furnace to stop it...can you help. Thanks,
Joel
RACTSAF is offline   Reply With Quote
Old 03-06-2012, 03:07 PM   #2
Possible board bad or open limit.
hvac5646 is offline   Reply With Quote
Old 03-06-2012, 05:53 PM   #3
confortmaker
Thanks...but which board are you talking about...the one on the blower motor or the pilot spark module board? Thanks!
Old 03-06-2012, 06:22 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Look at the bottom panel of the furnace and check to see what flash code you are getting and go from there.
You will see a sight glass on the panel and a green flashing LED. Count the flashes and post here
It is either going to be a high limit or a roll limit fault. Probably isn't the board.
Check filter to see if it is plugged.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-06-2012, 06:56 PM   #5
Rewards Points: 582
Joel
yes check to see if limit or some other safty switch is open ..when blower comes on.. thats a sign of over heat condition...inducer coming on at call for heat...
Old 03-06-2012, 07:09 PM   #6
Rewards Points: 560
Sorry Ben, But some ICP's equiptment has the inducer and blower come on at the same time for tripped high limit and roll out and not just a call for heat.
The Following User Says Thank You to Plumber101 For This Useful Post:
how (03-06-2012)
Old 03-06-2012, 07:16 PM   #7
Rewards Points: 582
no problem never seen one do that ..go to show never to old to learn
Old 03-06-2012, 07:33 PM   #8
Rewards Points: 560
See more with a roll out switch then a high limit, though
Old 03-06-2012, 07:49 PM   #9
Old 03-06-2012, 08:03 PM   #10
Hi all...Thanks for all the information...it was a safety switch on the left side of the burner...I pressed the reset button & now she is working great! Thanks for all the help...
Old 03-06-2012, 08:11 PM   #11
Rewards Points: 560
Now you need to ask yourself why did it trip?
Gas pressure to the burners to high?
Restricted flue?
How old is this furnace?
He'll be back.
Old 03-06-2012, 08:14 PM   #12
how
Rewards Points: 1,104
You now have heat but the more relevent concern should be what caused the roll out switch to trip. While it may just be a faulty switch it is often the first warning folks get with an exchanger problem
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Plumber101 (03-06-2012)
Old 03-06-2012, 08:19 PM   #13
Rewards Points: 560
Had one one time where the roll out was tripped. The HO showed me the problem and reset it in front of me. (I always look at the job before I bring in my tool bag) So I went to the truck to get my bag and when I walked in the front door it sounded like a freight train where the furnace was. Check gas pressure to the manifold and I almost fell backward when the manometer read 7.4 Inwc.
It's always something with roll outs I have never seen on just go bad.
Old 03-06-2012, 08:33 PM   #14
how
Hey 101
Mine was being called in after a supposedly reputable HVAC Co changed a home over to 2 lb gas for running new skinny fireplace lines and somehow forgot about the regular atmospheric furnace. The way it was shaking gave me a new appreciation for the anchoring qualities of solid black iron piping.
Old 03-06-2012, 08:35 PM   #15
Rewards Points: 560
I saw that where a supposedly reputable HVAC Co changed a home over to 2 lb gas for running new skinny fireplace lines and somehow forgot about the regular atmospheric furnace.
OUCH
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Carrier Model 58 PAV Furnace ccmyers2 HVAC 4 12-02-2009 08:13 PM
Ducane Model MPGA075B3B furnace SCLEM HVAC 1 11-02-2009 08:33 PM
