Confirming Correct Gas Pressure For New Furnace - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 07:31 AM   #46
Rewards Points: 150
Originally Posted by kennzz05 View Post
hey key have you noticed your post count seems stuck on 99? on another note please tell me that your post count includes answering other peoples questions on other forums and is not soley based on your questions here. heres a thought every time you think about static pressures or btu output or duct sensors for temp rise(are you kidding)go kiss your wife and perhaps show her the love you show your furnace. if you have young kids go read them a book but for christs sake stay the hell out of the basement. can you say o.c.d? sure, i knew you could. dude cmon!
ok let the fleeceing begin...
Wifee has her hobbies....and I have mine.
Key1
In the land of the blind....the man with one eye is king....
key1cc is offline   Reply With Quote
Old 01-22-2009, 08:30 AM   #47
Key1
Aw don't listen to them guys. So far you are almost a Podwan status. OnCE you have learned all the arcana and have mastered the the "Light Pyschrometer " you will be introduced into the Probationary Jedi Ranks.
But you must fight a DARK LORD OF HVAC, TO PROVE YOUR WORTH.... A SITH MASTER. HIS NAME: DARTH CLOVER!!!!
MWA_HAHAHAHAHAHAHAHAHAHAH.
hvaclover is offline   Reply With Quote
Old 01-22-2009, 08:40 AM   #48
Key1
Just an after thought, a song "Who's making love to your old lady, while you were out making love to Hvac?"
Changed up the title a little but this Biz can be so interesting you need tobe careful you aren't neglecting other parts of your.
Luck Key! You coming along fine.
Old 01-22-2009, 08:46 AM   #49
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
Beenthere is correct. There is nothing you can adjust to change the CO and other readings. I have setup conversion burners etc and you need to be able to adjust the primary and secondary air etc to change those readings. Setup your gas pressures and call it a day. Some new ductwork and a zoning system would be interesting/challenging/stimulating/good group project for us.
Old 01-22-2009, 09:09 AM   #50
Rewards Points: 150
Thanks Beenthere and Yuri for that insight. It was my understanding that the combustion should be checked and the CO values should be under 100 ppm and the O2 values between 6 and 9% with 6 being better than 9 (per the great Jim Davis).
As far as wifee goes, she has jumped on the bandwagon and is now pushing me to go to school and get certified as a HVAC'er as a back up in this recessionary environment in case I loose my day job (whatever the hell that is)
Key1
Old 01-22-2009, 09:12 AM   #51
Rewards Points: 150
ROFLMAO
I will tell her you inquired
Key1
Old 01-22-2009, 09:17 AM   #52
Hvac Pro
yuri's Avatar
Those figures are used to check for cracked heat exchangers etc. Lennox gives them to us as well. Nothing is adjustable other than the gas pressures. Have fun.
Old 01-22-2009, 07:41 PM   #53
Dr Heat's Avatar
Key1
Do her's use double A batteries I just ask cause well do they
Dr Heat is offline   Reply With Quote
Old 01-22-2009, 07:59 PM   #54
Rewards Points: 150
as long as I keep taking care of her 3 times a day ......She doesn't care what I do with the rest of my time...Can you say the same
Key1
Old 01-22-2009, 08:08 PM   #55
Rewards Points: 150
Actually the batteries kept running out...had to upgrade to plugin...
Old 01-22-2009, 08:38 PM   #56
Dr Heat's Avatar
when you gotta go to gas powered you Know you got a keeper and lets not even talk about Diesel
Old 01-22-2009, 08:48 PM   #57
An old Tradesmen
Rewards Points: 7,344
Key, your just gonna have to go to an NCI course.
Old 01-22-2009, 09:10 PM   #58
Rewards Points: 150
Already a member (Just got my January newsletter.)
Are you going to the big Summit in Dallas?
http://www.gotosummit.com/
Key1
Old 01-22-2009, 09:31 PM   #59
Rewards Points: 150
My choices are Air Diagnostics & Balancing, Mold Liability and Prevention, or CO/Combustion training.
The Air diagnostics will be in Philly (about an hour drive) in April...
Key1
Old 01-23-2009, 12:44 AM   #60
Take your wife's thermometer out of the kitchen draw and check the Temp rise of the furnace before messing with any pressures. The gas pressure setting on most furnaces for natural gas is 3.5" of water colum on high fire with a new air filter. Check the temp Rise and make sure you are with in manufactures specs. Temp rise should be found on one of the stickers insinde of the furnace usually in the burner compartment. Temp rise is suplly air temp (air leaving furnace) ( outside drect line of site but as close to the heat exchanger as possible) minus the reutrn air temp. Instead of buying a meter you will probally never use again. Never set your temp rise to its maximum as your filter clogs or you go from a cheap blue one to a better pleated filter your temp rise will increase. So Don't fix what you think is broken Fix what you know is broken. ( True Jedi Wisdom) Also Look at the way your furnace is burning If you can see the flames with out dismantling your furnace. check the temp. rise If you stand a few feet away from it You should see a nice blue flame with very little yellow at the extreme ouside of the flame. it should have a very very nice blue core. I say stand a few feet back because if you are standing to close stirring up dirt and dust into the air you Will see the flame Flash more yellow as you add dust to the fuel you are burning.
devlon is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Old Hot Water furnace won't hold pressure tconkey HVAC 3 01-28-2008 05:01 AM
RUUD Gas Furnace Pressure Switch? erik11 HVAC 8 12-06-2006 11:39 PM
