Condo Hvac Unit Replacement? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 05:04 PM   #1
condo hvac unit replacement?
customer has ceiling mounted electric furnace with a/c coil, condensor is remote. Unit is only 12 inch; deep by 36 inch wide and is serviced from the bottom. Unt is approx. 25 yrs. old and has multiple problems. I cannot seem to find any sort of replacement unit for this application. What are your suggestions?
dgrischow is offline   Reply With Quote
Old 12-29-2011, 05:07 PM   #2
Houston204's Avatar
Rewards Points: 556
First Company if we are cooling with refrigerant. McQuay if we are cooling with chill water.
Houston204 is offline   Reply With Quote
The Following User Says Thank You to Houston204 For This Useful Post:
dgrischow (12-29-2011)
Old 12-29-2011, 05:07 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
Talk to the sales reps from your major wholesalers/suppliers. They have spec sheets for the brands they sell. You are looking for an air handler with some supplemental electric elements inside and comes with an built in AC coil. The size of them varies by brand etc etc. Most of the major manufacturers have them. First Co does make some of the smallest units I have seen. Not impressed with the build quality though.
The Following User Says Thank You to yuri For This Useful Post:
Old 12-29-2011, 05:10 PM   #4
I have checked with my wholesalers and none of them have a unit with comprable specs.
Old 12-29-2011, 05:59 PM   #5
Can you post a pic of what you are looking for?
brandonmcginnis is offline   Reply With Quote
Old 12-29-2011, 06:00 PM   #6
Hvac Pro
yuri's Avatar
what brand are you removing? where are you and what size in tons of AC and how many KW of electric heat is in it? the old Lennox units are obsolete and they have airhandlers but they are a different size. we did a conversion of one and put a Nortron electric furnace on the floor with a standard AC unit and diverted the ductwork down to the floor to fit it. VERY nice setup.
Old 12-29-2011, 06:33 PM   #7
That's exactly why I wanted to see a pic! If he has one of the ceiling mount fan/strip/coil units I'm thinking he's got, they suck big time. They are usually jammed up in the corner of a tiny closet, which is invariably packed to the gills. I really, really, don't like those things.
Old 12-29-2011, 06:40 PM   #8
I'm Your Huckleberry
Rewards Points: 2,270
Goodman makes electric furr down units as well.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-29-2011, 07:57 PM   #9
Houston204's Avatar
Rewards Points: 556
I only see 2 of 3 dimensions in the original post.
First Co. has a 1.5 ton and a 2 ton ahu 10 high x 37 wide x 21 deep.
http://www.firstco.com/products/hx.asp
Armstrong Model 51HWC242A-9B HVAC unit - Furnace will not fire WisCheeseHead HVAC 7 12-29-2011 10:02 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 05:24 AM
Which HVAC Packaged unit Soetekouw HVAC 7 02-22-2010 10:31 PM
need advice on cleaning a/c unit in my condo mellow_yellow HVAC 1 05-17-2009 09:55 AM
