Conditional Attic Space - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 02:36 PM   #1
Hello,
I'm looking for advice regarding conditioning my attic. The attic is 1300 cubic feet volume with about 3 to 4" of spray foam insulation in the rafters; the attic floor is uninsulated with conditioned rooms below. The attic is only 4' high at the peak, so it's not a large space from a volume perspective. My HVAC unit is within the attic space. Currently I run a dehumidifier in the attic to keep humidity down during the summer. My goal is to use the existing HVAC system instead of the dehumidifier.
My thoughts are to provide a return in the existing return plenum which is already in the attic. The plenum is about 3'x3'x4', so there is plenty of room to add some type of return inlet.
For supply air I was considering tieing into one or two of the existing 6" ducts to the rooms below and running a couple of ducts to outlets within the attic. The AC unit currenty supplies the following ducts, all run within the attic space...
(3) 6" x 20' long, (3) 6" x 15' long.
First question is would this work? What about sizing? Should I install dampers to the return and supply lines? What size should the return in the plenum be? What size and how many supply lines should I run?
Thanks.
gandlbecker is offline   Reply With Quote
Old 07-07-2012, 04:56 PM   #2
The answer depends on what type of heat you have. If it's an 80% eff. furnace then no return in the space,there's already not enough free air for required proper combustion. A 90% furnace with outside air intake or electric heat would be fine though.
Old 07-07-2012, 06:57 PM   #3
An old Tradesmen
Rewards Points: 8,242
Hopefully you spray foamed the gable ends also. Run a separate supply for the attic. Don't take air from a supply for any of the below rooms. A single 6" is all you probably need. And 6X12 return grille in the return plenum. This will gt you to near human comfort level.
This is based on the furnace being a direct vent.
Old 07-07-2012, 07:47 PM   #4
Thanks for the input. Heat is electric, so that should not be an issue. Yes, the gable ends are also sprayed with foam.
Should I put some type of damper on the return? Should I be concerned about creating a vacuum in the attic? I already have a slight moisture problem and hate to make it worse by removing too much through the return.
What if I had no return at all? My thinking is that then I may cool the attic, but would not remove moisture. Is that correct?
Thanks again for the help.
Old 07-07-2012, 08:05 PM   #5
An old Tradesmen
That is correct.
You really only need a small supply, and return. You can use a return grille with a damper in it to adjust the amount or return your pulling. A 4" round supply will be enough to condition the space for humidity control. but better off with a 5".
excessive moisture in attic crawl space jimmy21 Building & Construction 11 02-19-2012 02:46 AM
Termite/Rats Attic and Crawl Space Vents connor016 Pest Control 4 01-30-2012 04:27 PM
Help...Framing Door Along Slanted Ceiling of Attic Space JDinh1985 Building & Construction 5 09-25-2011 10:50 PM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 06:19 AM
