Condensor Fan Position Question? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 09:07 PM   #1
Condensor fan position question?
When replacing a condenser fan motor how far should the fan blade extend into the schroud?
On the subject of condenser motors, if you have a 1/3hp motor @1075-1100rpm can you replace it with a 1/4 or 1/2 hp motor with the same specs other then HP ?
and it so would it be any benifit to using a stronger motor with the same RPM ?
Thanks,
Zog
hartzog86 is offline   Reply With Quote
Old 06-06-2011, 05:39 AM   #2
Best to stay with the original horse power or you'll be replacing it sooner. Same answer with the position, keep it the same as the original.
Tags
condenser , fan , motor , replacement
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 11:16 AM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
