Condensor fan position question?
4K views 1 reply 2 participants last post by  Marty S.
When replacing a condenser fan motor how far should the fan blade extend into the schroud?
On the subject of condenser motors, if you have a 1/3hp motor @1075-1100rpm can you replace it with a 1/4 or 1/2 hp motor with the same specs other then HP ?
and it so would it be any benifit to using a stronger motor with the same RPM ?
Thanks,
Zog
