Old 01-20-2011, 09:41 AM   #1
Condensor Fan not Working
While outside I noticed the Ducane Heat Pump Condensor was making a very loud humming noise and discovered that the Condensor Fan was not running. I was able to rotate the fan blade while it seemed to attempt to run. Would this be an indication that the Fan Motor is bad or does this sound like a bad capacitor ?
Woody Eppard is offline   Reply With Quote
Old 01-20-2011, 04:21 PM   #2
An old Tradesmen
Could be either.
Try a capacitor, and if that doesn't fix it, then its probably the motor.
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 07:23 AM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 10:28 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
