Condensor Fan Motor Runs Slow On RUUD - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 06:28 PM   #1
Condensor fan motor runs slow on RUUD
Its a 5kcp39fgn223as G.E. brand in a RUUD unit.
If it runs slow is the start capacitor stiil good and there is another large
cap too connected to it. If its running slow do you think the motor is just
gone. Its around 20 years old.
Do people ever rebuild these, wonder about that.
posterman is offline   Reply With Quote
Old 05-22-2013, 07:33 PM   #2
Rewards Points: 614
try new capacitor..... after you check for bearing play......
carmon is offline   Reply With Quote
Old 05-22-2013, 08:15 PM   #3
Slow fan
The startup that has been replaced some years back.
Its a long round one. The other large one never seems to give
trouble.
I will have to look for one on the net, will check the value of it.
No play in bearing.
Turns real smooth with no play.
Maybe replace the startuo with a
Supco hard start capacitor SPP6 SPP-6 I think that is what was put in it can't read writing on it.
The Run capacitor I don't think has ever been replaced but it looks ok and not swelled up etc.
Old 05-22-2013, 08:43 PM   #4
Rewards Points: 582
time to replace that 20 yr motor....sorry ben sr
Old 05-22-2013, 08:49 PM   #5
slow motor on condensor fan out side.
So you think the old motor is on its last leg. Can these be rebuilt?
Brushes cleaned up etc. People must have done that in the past
before people replaced them.
Old 05-22-2013, 09:02 PM   #6
Rewards Points: 582
you have to check it with a meter to see if cap is bad or if motor is bad or both ...no they don't rebuild them any more that I know of ....it would be cheaper to but new....ben sr
Old 05-22-2013, 09:46 PM   #7
Slow motor
Will have to get my meter out and see if I have voltage at the run cap
and at the hard start cap. I have replaced the hardstart, they seem to go. The other large cap I have never rplaced and it has never blown or
bulged up, looks real clean.
The old motor might have given up but no smell of burning etc from it.
The old ones I bet are built better then the new ones from CHINA.
Slow draining tub mgeller2001 Plumbing 3 07-04-2012 09:15 PM
New swamp cooler blowing slow CmdrPopNFresh HVAC 7 09-02-2011 02:19 PM
Replacing Slow Basement toilet NCJ Plumbing 3 12-09-2010 10:10 PM
Slow drain is still slow dav7612r Plumbing 14 08-01-2010 10:28 AM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
