Old 06-20-2012, 07:51 AM   #1
Condensor fan motor
My a/c quit working at the end of last summer and i just now replaced the fan motor. the original problem : the unit would run for 20 - 30 minutes then the fan motor would shut down , but everything else would still be running. A co-workers brother said condensor fan motor , so i replaced it with a 4mb23 / same as the old one , also replaced the capacitor at the same time. Unit is still doing the same thing , reading about other trouble shooting on here i replaced the contactor but the unit will run for about 20 - 30 minutes then the fan stops again. when it does run it runs smooth blows very cold , nothing freezing up and all the coils are clean and free of any dirt and debree , any suggestions on what to do from here.
glambert25 is offline   Reply With Quote
Old 06-20-2012, 08:33 AM   #2
JJboy's Avatar
Condensor fan motor
Are you sure the compressor still running?
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-20-2012, 08:54 AM   #3
Condensor fan motor
yes unit in house is running and blowing , outside unit is running but the fan is not
Old 06-20-2012, 11:17 AM   #4
Condensor fan motor
does anybody have any suggestions that i can do myself, any help is greatly appreciated
Old 06-20-2012, 11:32 AM   #5
I'm Your Huckleberry
Condensor fan motor
Hope you don't mind me budding in for second, JJboy.
Turn the breaker to the condenser off. Straighten out a wire clothes hanger or find a long thin stick or something that wil fit into the lid of the condenser and try and spin the fan blades. If they are hard to spin at all, if it shows any type of resistance to spinning freely, the motor is bad.
Also, with power ON and the system calling for cool which would mean the compressor is running as you say it is but not the fan, touch the lid of the condenser where the fan is mounted. If it's abnormally hot (meaning you need to remove your hand quickly to avoid being burned ) then the fan is bad.
Thanks.
Doc Holliday is online now   Reply With Quote
Old 06-20-2012, 11:40 AM   #6
Condensor fan motor
the fan motor will run , but only for about 30 minutes then gets hot the unit is still running but the fan is not, also this is a new fan motor , new cap and a new contactor
Old 06-20-2012, 01:30 PM   #7
JJboy's Avatar
Condensor fan motor
you need to have a multimeter with clamp for AMP connect to the fan. check if the Amp is ok all the time until the fan stop running.
Old 06-20-2012, 02:00 PM   #8
Condensor fan motor
we just finished the amp test as reccomended , all amps and voltage are good , but once the fan stopped the amps started to climb , once again all advise is appreciated
Old 06-20-2012, 02:27 PM   #9
Condensor fan motor
I was just told that i could have a bad blade causeing the motor to overheat and shut down , does this make any sense to anyone
Old 06-20-2012, 04:58 PM   #10
Condensor fan motor
Sounds like the bearings are over heating in the motor causing it to bind after a half hour of running. Weak capacitor can do that as well as a faulty motor. Sometimes they're bad right out of the box. If the fan blade was bent you would see it wobble while running and there would be a lot of vibration.
Old 06-20-2012, 05:04 PM   #11
Condensor fan motor
Thanks , i have checked the blade again and i think it is fine . funny how you mention bad motor or cap out of the box , just exchanged both the motor and cap at grainger , installed and still the same problem , i am lost on this one
Old 06-20-2012, 05:39 PM   #12
JJboy's Avatar
Condensor fan motor
What is the model and serial number of the condenser.....I wanna see the electrical drawing.....
Old 06-20-2012, 05:48 PM   #13
An old Tradesmen
Condensor fan motor
Are you sure its spinning in the right direction? Is this a heat pump?
Old 06-20-2012, 09:19 PM   #14
Condensor fan motor
yes it is spinning in the correct direction and its a coleman condensor unit
Old 06-20-2012, 10:05 PM   #15
JJboy's Avatar
Condensor fan motor
sn# ?????
How to replace condensor fan motor? twags HVAC 41 09-13-2012 07:05 PM
Old Rheem Air Blower Motor Wiring Problem CompoundNetwork HVAC 3 11-20-2011 04:51 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 04:59 PM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 12:42 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
