Old 08-14-2008, 07:14 PM   #1
Condensor drain
The condensor has a 5 ft. long 1" drain to a vertical 2" I.D. drain in a wall. The condensor drain makes a 90 degree turn to enter the wall drain. I have a pan and second drain to my soffit.
I plan to seal the condensor drain in the wall drain so the next overflow backs up into the condensor and then flows into the drain pan.
When I seal the condensor drain into the wall drain, do I need to put a vent stub at that point? The drain trap is in the wall about 30 inches below the condensor drain entrance.
Captflx is offline   Reply With Quote
Old 08-14-2008, 07:23 PM   #2
oops, did I do that!
Condensor drain
The secondary drain is in the soffet so that you can see there is a problem, if the primary drain backs up.
Sounds like the 2in drain is getting plugged up and overflowing. Is the 2in pipe trapped? If it is, sure seal it up and extend a vent higher than the pan, from the top of the 2in opening.
Just remember that the trap will dry out during heating season, and allow sewer gas to be drawn into the airhandler. There are automatic fills for traps, look into them before you commit to sealing it up.
Might just be easier to run a new 1in drain to a more logical location, and seal up the 2in drain.
8 Ball is offline   Reply With Quote
Old 08-14-2008, 07:32 PM   #3
Condensor drain
The 2" drain starts about 4" above the ceiling, travels down the wall into the slab. About 30" below the ceiling is where the drain trap is located.
Old 08-14-2008, 07:35 PM   #4
Condensor drain
Because the condensor drain is not sealed when it enters the wall drain, the back up never takes place in the pan. It overflows out of the 2" wall drain onto my ceiling.
Old 08-14-2008, 07:44 PM   #5
Condensor drain
Oh I understand what you mean. Some things just defy logic. Makes you wonder what the h**l were they thinking. Evaporator condensate doesnt have the velocity to clean the trap, so it just goobers up.
I would look for a new route for the 1in evaporator drain. Maybe to a laundry/utility sink.
Old 08-14-2008, 07:56 PM   #6
1610 CUB's Avatar
Condensor drain
For a $ or two you can get one of these
http://www.plumbersurplus.com/Prod/L.../64736/Cat/284
1610 CUB is offline   Reply With Quote
Old 08-17-2008, 11:19 AM   #7
Condensor drain
Thanks for the suggestions.
