Condensor Coils Will Not Stop Dripping - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 03:49 PM   #16
Rewards Points: 150
That is your coil, it looks like a radiator of your car...if water is dripping out the crap is still stuck in the coils.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 09-05-2012, 12:11 AM   #17
Wonder what the other side looks like.
Did he cut an access hole to clean both sides?
Evstarr is offline   Reply With Quote
Old 09-05-2012, 08:54 AM   #18
Evstarr,
The top side was pretty clean, none of the debris got through the bottom coils. But he did clean from both sides. I do not think he cut any holes, because both the top and bottom of the foil is accessible from the front of the unit when the cover is removed.
Dan
dman53 is offline   Reply With Quote
Old 09-05-2012, 10:45 AM   #19
Rewards Points: 610
That IS the COIL or as it is officially known as the "A" COIL because it forms a sort of A shape in the duct. It is either,...still clogged and maybe has to come out to be cleaned properly OR it may have bent/damaged fins..that's the tiny little blades that form the "mesh" part of the A COIL if they are severely bent that could also act like a blockage..Air Conditioning mechanic should have tool (special comb) to straighten them if necessary. May have to cut an access hole in the duct to access the A COIL in order to clean it out properly or straighten fins..should be able to shine light through all portions of the coil and see the light shine through to other side.
techpappy is offline   Reply With Quote
Shut off both valves, one won't stop dripping Katy H Jordan Plumbing 5 01-17-2012 07:28 PM
How to stop dripping bathroom faucet colden Plumbing 14 12-08-2010 12:13 AM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Hinge Pin Door Stop exterior dws General DIY Discussions 5 02-17-2009 10:58 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
