Condensing Unit Shuts After 5 Mins - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 03:48 PM   #1
condensing unit shuts after 5 mins
trane xe 1000 -
1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc
everything starts, runs, cools -cold air - but only for about 5 minutes...then condensing unit shuts off - inside blower keeps running though... I'm thinkin thermostat....you?
tboca007 is offline   Reply With Quote
Old 08-25-2010, 04:30 AM   #2
An old Tradesmen
Rewards Points: 7,826
I'm thinking it would work better if it had the right motor.
Might be that that motor spins the opposite direction. Or. Your seeing a problem now, that caused the other motor to go bad.
Replacing a condensing unit with a higher SEER rating unit tylanz HVAC 3 06-28-2010 04:44 PM
Trane condensing unit keeps running fastback4 HVAC 1 06-08-2010 06:49 PM
Outside Condensing Unit not working Will B HVAC 3 05-07-2010 06:11 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
New Condensing Unit to Match Existing Air Handler? sweaty HVAC 5 03-04-2009 12:37 PM
