Condensing Unit Lines - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 04:48 PM   #1
Rewards Points: 1,596
Condensing unit lines
New a/c unit.
Should the one line in the picture have more insulation on it?
I noticed when unit is running that both tubes seem cold. Shouldn't one be warm/hot and the other cold?
Thanks,
Bob
bob22 is offline   Reply With Quote
Old 05-31-2011, 05:15 PM   #2
That missing cap on the suction valve is a bigger problem then the missing 6" of insulation. Call the installers back and make sure they check the subcool or superheat according to the directions. The little line should not be cold.
Old 05-31-2011, 05:16 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
The small liquid line should be warm and the big one should be cool. (general statements depending on where you live, outdoor temp and humidity, heat load in house etc). Older units used to run where the big one/suction line was COLD and sweating and the small liquid line could get warm to hot. The newer higher SEER units don't go to those extremes. A bit more insulation would help but is not necessary. Most important part is that the installer checked the operating pressures and superheat or subcool depending on what system you have.
Old 06-01-2011, 05:50 AM   #4
Thanks all. So the missing cap can lead to leakage? This was done about 3 weeks ago. Is this enough time for sufficient leakage to have occurred to demand that they check operating pressures and superheat/subcool? Should I assume the unit has a low pressure cut-off to prevent damage to compressor if it goes too low (a new York unit)?
Old 06-01-2011, 06:11 AM   #5
Schrader valves are not supposed to leak but sometimes they don't seat correctly. Checking the charge with SH/SC is standard procedure so ask them to check it and note the results on the service ticket along with the factory recommendation. Techs get paid to keep customers satisfied with the company service and we'll gladly do it, shouldn't be any need to demand.
The Following User Says Thank You to Marty S. For This Useful Post:
bob22 (06-01-2011)
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
AC Window Unit Size, 10k or 12k? Tuksonrider HVAC 7 06-17-2010 11:35 PM
Trane condensing unit keeps running fastback4 HVAC 1 06-08-2010 06:49 PM
Plumbing Help for installing RO Unit and Dishwasher hellothere123 Plumbing 1 10-25-2009 07:50 PM
