Condensing Unit/A-coil Help - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 10:04 PM   #1
Rewards Points: 31
Condensing unit/A-coil help
I am looking to add central air to the house we just purchased this past fall.
The house is 1287 on the main, 583 lower and 217 upper level for square footage.
I need to figure out how large of an A-coil to buy, and what tonnage I would need.
I picked up a York Model H1RA048S25G condensing unit. But nowhere on the unit does it say what ton it is rated at.
It has the model # listed above.
7lbs 5oz R22 charge
High side pressure 350
Low side pressure 300
and the serial number.
I have called the local and they were no help at all.
Any help would be appreciated.
Willis
shoothebunnies is offline   Reply With Quote
Old 04-28-2011, 10:09 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you bought most likely WAY too big of a unit, you bought a 4 ton unit 48,000 btu
you need to return the unit and have a load calculation done on your home.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-28-2011, 10:14 PM   #3
Rewards Points: 31
Not what I wanted here but thank you.
Next question is how to I calculate the load on my home?
Willis
Old 04-28-2011, 10:18 PM   #4
JJboy's Avatar
Willis
http://www.mrhvac.com/loadcalcshortform.htm
http://www.hvaccomputer.com/ ==> $49
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 04-28-2011, 10:20 PM   #5
AKA HVACTECHFW
there is software you can buy on the internet (google manual J load calculation) or pay a local contractor to do it for you.
IT IS WHAT IT IS
Old 04-28-2011, 10:21 PM   #6
Rewards Points: 31
Thanks for the help guys!
Willis
Condensing Coil Replacement RmW HVAC 4 05-06-2010 07:08 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 06:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
