Condensing Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 03:46 PM   #1
condensing pipe
I will soon replace my hot water boiler for my HW baseboard system. The boiler is located in attached about 15' from outside wall for a horizontal vent to exterior. Is that too far? Any recommendations for boiler manufacturer? Thanks..
mikalino is offline   Reply With Quote
Old 02-12-2009, 06:23 PM   #2
An old Tradesmen
Rewards Points: 6,846
Located in attached what?
The Following User Says Thank You to beenthere For This Useful Post:
mikalino (04-21-2010)
Old 02-12-2009, 06:28 PM   #3
The manual for the boiler will specify the maximum length of intake / exhaust pipes.
Reilley is offline   Reply With Quote
The Following User Says Thank You to Reilley For This Useful Post:
Old 02-12-2009, 09:19 PM   #4
Sorry! attached garage
Old 02-12-2009, 09:44 PM   #5
JohnH1's Avatar
If you are replacing with a high efficency 90%+ you are well within most boilers abilitys. Keep in mind you do not get full efficiency out of the boiler in a hot water baseboard system due to the high required water temps for baseboard.
JohnH1 is offline   Reply With Quote
The Following User Says Thank You to JohnH1 For This Useful Post:
Old 02-13-2009, 05:03 AM   #6
An old Tradesmen
As John said, 15' is well within most, if not all high efficiency boilers flue requirements.
High efficiency boilers require that they have proper water flow through them. Or they will use more fuel then a regular boiler will.
I prefer the Weil McLain Ultra.
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
