Old 01-02-2013, 04:29 PM   #1
Condensing furnace not condensing??
Hello all and a Happy 2013 to all.
My question is a simple one. My early 2000's Lennox Merit 90UGF doesn't seem to be producing any water out of it's condesate drain. No other wate leaks in furnace bay. Is this normal?
And yes the drain line is clear and properly routed too.
mlijoi is offline   Reply With Quote
Old 01-02-2013, 06:40 PM   #2
An old Tradesmen
Check air filter.
Old 01-02-2013, 06:49 PM   #3
It's clean, just some dust buildup
Old 01-02-2013, 08:31 PM   #4
An old Tradesmen
Too ow of air flow, over over firing can cause no condensate.
Old 01-02-2013, 08:41 PM   #5
it can indeed......
carmon is offline   Reply With Quote
Old 01-03-2013, 04:02 PM   #6
Ok, that makes sense. I had a gas man come last year and he made an adjustment with a really old manometer (not digital) and he bumped up the pressue a 1/4 turn so now it's probably over firing. Which way turning the screw reduces pressure?
Old 01-03-2013, 07:12 PM   #7
An old Tradesmen
Should only be adjusted using a manometer.
I still have a couple old ones. And they work as well as any of my newer ones.
Don't assume its over fired. check it with a manometer, or have someone check it. under firing is as bad as over firing.
Old 01-03-2013, 07:38 PM   #8
Ok thanks, im going to do a meter clocking asap.
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
lint/dust from furnace uksparky HVAC 15 02-16-2012 06:01 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
