Condensing Furnac Vent: 4' Through Roof Or 20' Through Gable? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 05:52 AM   #1
Rewards Points: 81
Condensing furnac vent: 4' through roof or 20' through gable?
Hi,
I'm working with contractor to install a new 96% efficient furnace. One of his recommendations seemed odd. When I told him I'd like him to do the roof penetration, he said "we won't mess with the roof, we'll bring it out through the gable."
Well, the roof is 4' above the ports, and the gable is about 20 feet away. Are roof penetrations really that troublesome? A-frame, typical tar shingles with embedded grit.
Thanks in advance!
-Jeff
mysterylectric is offline   Reply With Quote
Old 01-19-2011, 08:05 AM   #2
HVAC / Plumbing
Have cut the roof many times. If I didn't have to . I wouldn't. I have heard roofers thell that if you cut their new roof . they (roofers ) will void warranty
kenmac is offline   Reply With Quote
Old 01-19-2011, 08:47 AM   #3
HVAC Contractor
Jeff, there may be a minimum distance for venting (6' on some makes) but I also would go out the side if it is an option.
1acman is offline   Reply With Quote
Old 01-19-2011, 03:33 PM   #4
Rewards Points: 81
Thanks guys, looks like a concensus. Yeah, the manual suggests a superfluous jog (4 elbows) for short runs.
ridge vent vs. gable ceiling fan snarkk Roofing/Siding 1 09-22-2010 04:06 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 11:31 AM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
