Condensing Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 12:22 AM   #1
condensing coil
I took off outside covers to clean .i found a perfect line around the inside of coil. if it is made at factory shouldnt I get a new one? its still under warrenty shipping + labor ill try 2 post pics
condensing coil-sunp0006.jpg   condensing coil-sunp0004.jpg   condensing coil-sunp0005.jpg   condensing coil-sunp0009.jpg
billmill5050 is offline   Reply With Quote
Old 05-02-2011, 02:06 AM   #2
I would doubt that most manufacturers would swap a unit for fin damage. I would suspect that this would make virtually no difference in the performance of the unit, and you could fix it with a fin comb. I've seen several warranty statements that specifically exclude manufacturing defects of the coil/fin assembly.
Robo_geek is offline   Reply With Quote
The Following User Says Thank You to Robo_geek For This Useful Post:
billmill5050 (05-03-2011)
Old 05-02-2011, 05:33 AM   #3
An old Tradesmen
Rewards Points: 6,124
Did you buy the extended labor warranty. The standard factory warranty is part only, no labor or accessory items included.
The Following User Says Thank You to beenthere For This Useful Post:
Old 05-02-2011, 08:31 AM   #4
When they manufacture the coil they install the aluminum fins on the tube. This looks like where they started a new aluminum strip.
If the system is operating ok i would not worry about it.
Artco is offline   Reply With Quote
The Following User Says Thank You to Artco For This Useful Post:
Old 05-02-2011, 03:06 PM   #5
leak
i have leak some where a/c people cant seem 2 find there quessing thats it
Old 05-02-2011, 03:47 PM   #6
An old Tradesmen
A good company would use a trace amount of R22, and then bring the pressure up with nitrogen and find the leak.
The manufacturer's warranty is for part only, not labor or any refrigerant, driers, etc. So I sure would want to know where its leaking before spending money to replace a coil that probably isn't leaking. And then get a bill fro m them if the warranty is denied.
Old 05-02-2011, 04:40 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
MOST of the time when a cond coil leaks it leaves behind a large oily spot so they should see it on the coil if that is it. I have seen lots of fins like that and none of the coils leak. VERY rare that a cond coil leaks. Most of the time it is the welded joints outside or the evap coil inside. I have had to use nitrogen and bring it up to 150 psi B4 a tiny leak on a cold weld on a service valve fitting showed up and I had to STARE at it for several minutes to see the bubbles. Would not bubble at 125 psi and you think it should. Takes years of frustration and experience to be a good leak finder.
The Following User Says Thank You to yuri For This Useful Post:
Old 05-02-2011, 09:00 PM   #8
If you still have some pressure in the system you can try spraying that are with bubbles. But yuri is right, if there is going to be a leak on the condensing coil it will be at the metal sheet where the u bends are. If you want to find that leak pressurize to 300lbs.
Hubcap626 is offline   Reply With Quote
The Following User Says Thank You to Hubcap626 For This Useful Post:
Old 05-03-2011, 01:11 AM   #9
I'm more an automotive AC guy but my Tifco electronic detector seems to work very well for even those tiny leaks. Some automakers put fluorescent dye in the refrigerant oil from the factory (nissan), which makes the job easier.
Old 05-03-2011, 06:28 PM   #10
condensing coil
what can a reg.joe do if not licenced to get freo n ? can i but nitrogen? can i close valves and put in pressure coil with air tank? the lines are cut and brazed closed about 6 inches from service valves i should be able to try something with out paying with no results
Old 05-03-2011, 06:33 PM   #11
Hvac Pro
yuri's Avatar
Not much you can DIY. There are special procedures to leak test units. Cannot use air as it is a non condensible gas and will introduce moisture into the system and create acid and other problems. I would suggest a better service company and as mentioned there is a dye kit (dye) which can be added to the lines. Unit is then run for a day and they come back and use a "black light" to see if they can find the leak. The better more experienced techs know how to do that procedure and have high quality electronic leak detectors. The rest don't.
Old 05-03-2011, 06:40 PM   #12
condensing coil
would they do it as a service charge here their about 69 to 89 bucks
Old 05-03-2011, 06:42 PM   #13
An old Tradesmen
You can't legally get R22.
Air should never be used to pressurize lines that have had oil running through them, as it can cause an explosion, as oil and oxygen are not friendly with each other.
While nitrogen can be used to pressure test the lines. You will also need a regulator for the nitrogen tank. As the tank will have 2,000 PSIG of pressure in it.
Old 05-03-2011, 06:48 PM   #14
An old Tradesmen
The good dye is expensive, and using the HI black light is an additional charge. A good company, isn't gonna be cheap.
Old 05-03-2011, 06:51 PM   #15
can i buy nitro?
Condensing Coil Replacement RmW HVAC 4 05-06-2010 07:08 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 06:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
