Condenser's Fan & Compressor Run Stop Run Stop Run Stop, Please Help! - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 08:41 PM   #1
Condenser's fan & compressor run stop run stop run stop, Please Help!
My condenser's fan & Compressor runs for about 10 seconds; then stops for about 5 seconds; then runs for 10 seconds again; then stops for 5 seconds. It acted like this since I turned on the AC yesterday. Does anybody know why it acts like this? Help! I did replace the capacitor with a new one; but the problem is still there. Please see my video on youtube for more info:
tuanngnt is offline   Reply With Quote
Old 03-31-2012, 11:00 PM   #2
Rewards Points: 616
most likely cause is short of refrigerant.... low pressure switch doing what its supposed to do ... save the compressor
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
tuanngnt (04-01-2012)
Old 03-31-2012, 11:31 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Or a drain float switch?
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 04-01-2012, 12:02 AM   #4
Rewards Points: 582
it may have a high pressure cut off as well..
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 04-01-2012, 12:09 AM   #5
Thank you for all the replies; so look like I need to pump freon into it then; but it keeps run and stop at the short time, I worry that freon can not get into compressor. By the way, what is drain float switch? Where is it located at? and how is it look like?
Old 04-01-2012, 12:16 AM   #6
It can not be a drain float switch because I did not have one on my drain pan inside unit and this problem occured on outside unit.
I think low freon might be a problem and thank for that tip.
Old 04-01-2012, 08:04 AM   #7
I hook up the charging kit into the high pressure and low pressure pipes. I notice the high pressure pipe is way low. With the system run and stop in the short time, will I be able to pump freon into the system using the charging kit (blue, yellow, red wires).
Old 04-01-2012, 11:37 AM   #8
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like you need to hire a pro.
Let's throw out Super heat or Sub cooling for checking the charge.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 04-01-2012, 12:07 PM   #9
An old Tradesmen
Rewards Points: 6,544
Freon? What is the number on the refrigerant you are going to try and use?
You said the high side was low. What was its reading? What was the low side reading? What was the outdoor temp?
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-04-2012)
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
