Old 07-11-2014, 04:59 PM   #1
Share |
Condenser Unit Wiring Question
I'm more of a commercial HVAC controls guy, but I have an idea of how a residential condensing unit works. Any insight from a expert would be appreciated.
I'm tearing apart a condensing unit I got for free after the compressor seized up. It was under warranty and the factory said to scrap it, so I thought it would be interesting to dig into.
On the fan, it shows this:
Does that mean that the brown wire gets energized when the fan gets power? I'm assuming so since the brown goes to the capacitor and then off to the compressor? Thanks for any help.
52Caddy is offline   Reply With Quote
Old 07-11-2014, 05:15 PM   #2
Hvac Pro
Yep. It is a PSC permanent split capacitor type motor. Google that for more info.
The Following User Says Thank You to yuri For This Useful Post:
52Caddy (07-11-2014)
Old 07-15-2014, 04:55 PM   #3
I was working with a friend and he pulled wire off but didn't see where, I have two capacitors one large one and small one its on my g+ photos the large one is wired but the small one is not so I think a black wire should be on one end of capacitor to charge it or does that supplied by one of the two brown wires from the fan motor??its driving me crazy!Please anyone!!TY
thetruth is offline   Reply With Quote
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 11:22 AM
Wiring question for replacing compressor fan motor for a two ton Presidentiol Condensing Unit Charles11 HVAC 2 07-15-2012 09:26 AM
Hot Tub Wiring Question - Wire Type? AidanD55 Electrical 10 03-18-2012 12:16 AM
Condenser unit waranty frank otero HVAC 14 02-11-2011 04:06 PM
Compatability question (cooling unit to heat pump) Common HVAC 2 10-28-2009 07:44 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
