take a pipe wrench and put it in a bucket of ice water...
then place it on the pipes just up from the valves/shradders and torch awaythe heat from the torch will go up into the wrench.some cleaning and flux will make it flow on the pinch.trick slide a 2x4 brick under the pipe heat it up NOT red...
hammer it on the opening you good to go..this thing being store and or moved.get a vac on the condenser with a shot of freon to hold..don't leave it atmospheric...
95/5 will do it also with less heat just be super clean on those end cuts or the solder wil be rolling off...
