Condenser Placement - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 02:38 PM   #1
condenser placement
How much air flow does a condenser need
Petersdn1 is offline   Reply With Quote
Old 04-17-2013, 02:49 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
lots.
unit should have at least 1-2 feet between it and any walls so it can be accessed to clean the coil and serviced. no putting it under decks either.
Old 04-17-2013, 05:38 PM   #3
An old Tradesmen
Rewards Points: 6,550
Depends on its BTU rating/size. Anywhere from 650 to 1200 CFM per ton/12,000BTUs.
Old 04-17-2013, 05:45 PM   #4
Rewards Points: 1,216
Condensing units come with installation instructions and diagrams showing minimum distances to walls, overhangs, obstructions.
The information will include the dimensions required for servicing.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
hvactech126 (04-17-2013)
Old 04-17-2013, 07:27 PM   #5
Experienced HVAC Tech
HVAC1000's Avatar
At least 18" from a wall or fence is require here
HVAC1000 is offline   Reply With Quote
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 08:57 PM
Air conditioner condenser placement question sbkim HVAC 5 07-04-2012 01:43 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
