Condenser Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 08-27-2014, 08:53 AM   #1
Condenser not turning on
I have a goodman clj60-1c and last night it stopped blowing cold. The fan in the condenser is on and spinning (appears to be normal speed). But the condenser is not kicking on. About every 30 seconds it makes a short buzzing noise then goes away. I'm pretty handy at diy just never had to tackle an a/c. I found the electrical area on the condenser but not sure where to start. Any suggestions?
I also maintain the system so I know it's none of these... It has new air filters, about 15 days old, the condenser is rinsed every month, and the drain pipe is also cleared every month with air compressor and then bleached.
clearwaterjosh is offline   Reply With Quote
Old 08-27-2014, 08:58 AM   #2
Rewards Points: 3,256
I would check the compressor run capacitor first. Look for obvious signs like bulging. If it looks OK check to see if it measures the correct micro-farads or just replace it.
zappa is offline   Reply With Quote
Old 08-27-2014, 09:32 AM   #3
Rewards Points: 338
probably run capacitor, sometimes they bulge and sometimes not. if it's bulged it's most definitely dead or on its way out, if not you need to test it.
NitroNate is offline   Reply With Quote
Old 08-27-2014, 10:19 AM   #4
Thanks, taking it off now to get a new one. It does not appear to be bulged but for $30 I'm going to start with this and see.. I'll post again if it does not work... Thanks
Old 08-30-2014, 01:11 AM   #5
I'm Your Huckleberry
Rewards Points: 2,270
"Bulged" is just one tell tale sign. It could look brand new and be bad.
Please let us know.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-30-2014, 12:39 PM   #6
It was very slightly bulged. Replaced it and works! It was actually a very easy fix. Thanks for the help.
The Following User Says Thank You to clearwaterjosh For This Useful Post:
zappa (08-30-2014)
Carrier condenser fan always turning slowly when off Exjay HVAC 7 04-29-2013 10:17 AM
Condenser fan not turning under power PHILAND HVAC 1 07-19-2012 09:15 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Condenser and Blower not turning on nEmEsIs15dead HVAC 11 08-09-2010 10:56 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
