-   -   Condenser Motor Tango Uniform? (http://www.diychatroom.com/f17/condenser-motor-tango-uniform-63563/)
toleg 02-03-2010 11:46 PM
I have a Comfortmaker 10 that's been here longer than I have, so it's more than 10 yrs old. The landlord has looked after it until recently, now it's on me. A while back the outside fan motor began to have trouble spinning. I could give it a "push-start", and it would then kick in and accelerate up to speed. Based on this I figured I needed either a new hard start cap (there was already one there when I looked at it) or maybe a switch to a stronger cap.
The problem now is that the fan acts as though it's siezed up when there is power to it. If I try to push the blades, there is much more friction, whereas before the fan would turn easily. Also, when I disconnect the power by removing the outside fuses, the fan blades do spin freely. No smoke, no smells, lots of moaning -from the unit, I mean.
Once or twice I was able to get the fan going with a strong push. It would struggle to generate some RPM, then would stop after about 10 to 30 seconds.
Could a new hard start cap fix the problem, or is the motor T*** U*?
What do i do next?
beenthere 02-04-2010 12:52 AM
The motor is toasted.
Hard starts aren't generally not used on fan motors.
You may be thinking a run cap is a hard start cap. its not.
SULTINI 02-04-2010 06:23 AM
If and when you buy a new motor don't forget the new capacitor to go with it.
peyton 02-04-2010 11:28 AM
lubrication
Could the motor just need some lubrication? Mine seized up and the tech put a little oil (it has oil ports) in it, worked it around a bit and voila! It's been several years now with no problems. I do now oil it yearly.
Peyton
beenthere 02-04-2010 12:31 PM
Peyton
He said the blades spin freely without power to the motor.
What he describes is a winding to winding short causing a shunt.
It will smoke if its left powered like this for too long. And can weld the contactor contacts together.
peyton 02-04-2010 12:51 PM
Missed that sentence. Sorry
Peyton
toleg 02-04-2010 09:59 PM
You're right beenthere, I did think that. thank you for clarifying.
toleg 02-04-2010 10:00 PM
Peyton
No oil ports, unfortunately
toleg 02-04-2010 10:05 PM
Beenthere,
That makes perfect sense to me, and is oddly reassuring. At least I don't have to keep questioning what is wrong. There's no way to repair the windings, is there?
