Condenser Motor And Capacitor Confusion - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 08:01 PM   #1
Question
Condenser motor and Capacitor confusion
I would like to get some advice from the forum if possible; this is my first post here. I have a condenser motor that seized up on me. Easy enough fix, bought a replacement motor (same H.P and Rpm as my old motor could not easily be cross referenced)
The OLD motor Had a
(1)-Black (Power source)
(2)- Brown (Fan plug on Capacitor)
(3)- Yellow (Plugged into Capacitor labelled (C)
The OLD Capacitor had (3) Inputs
(1) FAN- Brown Wire plugged into It
(2) C- Yellow Motor Wire and Yellow AC Wire plugged into It
(3) HERM- BLUE wire coming from AC into it
The NEW motor has-
(1)- Black Wire- (plug into Power Source)
(2) Brown- (Plug into capacitor Side)?
(3) Brown Stripe-(plug into other capacitor side)?
(4) White- ?? Label says black and white 208-230 Volt Line? Do I plug it into anything? Is it the Ground?
The NEW Capacitor has (2) inputs neither of which are labelled as anything.
So My questions are these-
1. Is the new White from the motor a ground?
2. Does it matter what side the Brown- Brown/Stripe get plugged into on the Capacitor?
3. Where does the BLUE AC wire now go that was plugged into the old (HERM) spot?
4. Where does the Yellow AC Wire now go that was plugged into the old (C) spot?
Thank you greatly for any help you may be able to provide!!!!!
ryanru is offline   Reply With Quote
Old 06-24-2010, 08:17 PM   #2
Black goes to the same as the old black. White goes to the other leg of the contactor, the one the black is NOT on. The two browns go to the new capacitor.
The Following User Says Thank You to Marty S. For This Useful Post:
ryanru (06-24-2010)
Old 06-24-2010, 08:28 PM   #3
Thanks Marty-
Any Ideas on-
a- The Yellow wire mentioned above is exiting the bottom of the contactor- Can I Wire the white to it>
Thanks again!!!!!
Old 06-24-2010, 08:56 PM   #4
You still need the old capacitor for the compressor. Leave the C and herm wires where they were. Yes you can wire the white to the C terminal on the old capacitor or to the same side of the contactor that the yellow goes to. Both are the same thing so it doesn't matter.
You'll have two capacitors now instead of one. Don't think I made that very clear.
Old 06-26-2010, 12:54 PM   #5
Talking
Thank you!!!!
Thank you very ,very, very much!!!!!!!!!!!!!!!!!!!
Old 06-26-2010, 01:25 PM   #6
Hi everyone -- I have a similar situation to the above poster: going from a 3 wire fan to a 4 wire fan.
My compressor fan in a 21 year old Carrier (model 38TK024300) started turning very slowly last night (probably about 100 RPM or so). So my first thought, after reading some forum posts, was to replace the capacitor. I did this, but I had to replace the old dual capacitor with two "single" ones. The uF and voltage ratings for the compressor and fan sides are the same as the original, so no worries there.
OK, so this did not solve the problem (fan is still turning slowly and compressor doesn't come one [hopefully the compressor is in some sort of "protection mode" rather than just dead!]).
So now i'm replacing the fan. My original fan is a GE model HC35GE230A. The replacement fan I was just sold is an A. O. Smith model (#FE1018SF).
The old fan has a black (hot) wire, a yellow wire connecting to the C terminal of the old dual capacitor and a brown wire which connected to the "fan" terminal of the capacitor. The new fan has 4 wires: black, white, brown, and brown/white. The black and white wires can be reversed (via a small plug) in order to achieve the correct fan direction.
So, I've seen two options for how to wire this thing (and I'm not sure which is best, or if it even matters).
Option 1: connect black wire as before (same as original motor), connect brown to one pole of the fan capacitor, connect brown/white to other pole. Finally, connect white wire to same pole as brown/white.
Option 2: Same as above, but do not connect brown/white.
FYI: the fan and compressor capacitors are bridged by a connecting wire right now -- I was told that this setup is the same as a dual capacitor. So to clarify, brown fan wire goes to one post of fan capacitor, brown/white and/or white motor wire will go to terminal #2 (depending on option 1 or 2 listed above). Terminal #2 has a wire going to a terminal on the second (compressor) capacitor. That terminal of the 2nd capacitor also has a yellow wire going to the compressor. Finally, the second terminal of the compressor capacitor has a thicker blue wire which also feeds into the compressor.
Hopefully I'm on the right track... thanks ahead for anyone's advice!
frazwr01 is offline   Reply With Quote
Tags
motor condenser capacitor
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 11:09 AM
Condenser freezing zep HVAC 2 01-30-2010 09:04 PM
AC Condenser source of ignition? hrjrkr HVAC 4 09-16-2009 12:33 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 12:02 PM
