Condenser Freezing - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 01:51 PM   #1
zep
Condenser freezing
Due to roughly 6" of snow and continued freezing rain today, the condenser housing louvers are freezing up on the sides. I have removed snow from the top and away from the bottom of the condenser. The heat pump condenser coil does routinely go into defrost and melts any ice off the coils. My concern is the possible airflow resistance over the condenser housing air louvers. Can I take a hair dryer to melt the ice off the housing with out doing damage to the condenser?
zep is offline   Reply With Quote
Old 01-30-2010, 05:26 PM   #2
HVAC Tech/ Browns Fan
No it maybe low on freon, defrost switch bad, defrost board bad or bad heat txv. You may need to call a pro this time. Go ahead and turn on the emerg. heat for now
Tator1076 is offline   Reply With Quote
Old 01-30-2010, 08:04 PM   #3
An old Tradesmen
Rewards Points: 7,372
Depending on model.
Its common for them to freeze like that if they're ran during freezing rain.
Turn it off. Thaw it with something(hair dryer plugged into a GFCI recep).
Turn it back on. make sure it defrost as normal later tonight.
Heat and Condenser running at same time emmark22 HVAC 2 01-12-2010 12:28 AM
AC Condenser source of ignition? hrjrkr HVAC 4 09-16-2009 11:33 AM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 11:02 AM
Cover a condenser during snow? GooperMC HVAC 4 12-16-2007 06:36 PM
