Condenser Fan Stop/Start - Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2009, 03:13 PM   #1
When my heat pump comes on the outside condenser fan will initially run for 30 seconds then it will shut off. Once the blades stop spinning it will start up again. Then it will shut off after 20 seconds. This cycle keeps repeating. What would cause the fan for the condenser to stop and start repeatedly?
Thanks for the help.
mkurley is offline   Reply With Quote
Old 02-02-2009, 05:04 AM   #2
An old Tradesmen
Rewards Points: 6,464
Loose connection.
Bad defrost board.
Old 02-04-2009, 08:48 AM   #3
Could it be that the fan is out of balance? If the fan is out of balance and vibrates too much would it automatically shut off?
Old 02-04-2009, 12:58 PM   #4
An old Tradesmen
If its far enough out, it might.
Does it shake enough that the outdoor unit looks like its going to fly apart.
Old 02-04-2009, 01:54 PM   #5
The unit vibrates but it looks like a normal vibration. Nothing too crazy. I even held the unit with my hands so the vibration stops but it still shuts down.
Old 02-04-2009, 03:06 PM   #6
An old Tradesmen
Its possible that if its had that vibration for long enough, it could have damaged the bearings.
But, there are a lot of units out that have a vibration like that, and the fan is still going strong years later.
Needs to be checked with a meter, to find out why its stopping.
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Heat pump condenser fan missing: how do I know what to replace it with? Ptron HVAC 9 11-29-2008 01:46 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
