Condenser Fan Running Backwards,towards Coils? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 12:41 PM   #1
Exclamation
Condenser fan running backwards,towards coils?
Just noticed today that the fan on condenser unit outside is running backwards(blowing into coils) What could be the problem? Not really a major problem I just live in Columbia,SC! Never gets very hot here LOL
Mr.Pappy is offline   Reply With Quote
Old 07-07-2012, 02:08 PM   #2
JJboy's Avatar
You can select clockwise or counterclockwise by connecting and disconnecting to small wires.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-07-2012, 09:58 PM   #3
as seen on tv
Rewards Points: 150
Test the run cap if it test ok reverse the wires
qbert is offline   Reply With Quote
Old 07-07-2012, 10:00 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
replace the capacitor.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
How to clean evaporator coils loftezy HVAC 13 12-22-2011 10:41 AM
Condenser unit not working? kcombs816 HVAC 9 07-05-2011 09:24 AM
Seer 10 evap coils bad, Go to Seer 13??? pcumming HVAC 5 09-01-2010 06:21 PM
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 11:09 AM
Heat and Condenser running at same time emmark22 HVAC 2 01-12-2010 01:28 AM
