-   -   Condenser Fan Running Backwards! (http://www.diychatroom.com/f17/condenser-fan-running-backwards-153096/)
slickwilliam 08-08-2012 07:48 PM
It's a high-efficiency builder's grade unit about 10 years old and has been running perfectly until today. House got very hot this afternoon and I went out to check the unit and realized the condenser fan was running backwards - drawing air in at the top and blowing it out through the coils. The unit is working - kind of - but this obviously indicates a problem.
Any ideas?
turnermech 08-08-2012 08:22 PM
if it is the oringinal motor (not reversable) and it is single phase (not three phase most often found in commercial), it is the capacitor most likely. Capacitor starts the motor and starts it in the right direction.
slickwilliam 08-08-2012 08:53 PM
Thanks. I looked at the wiring (after pulling the disconnect, of course). Thought I might see some signs of a bad cap (case swelling, etc.). Nothing obvious. But when I plugged in the disconnect, the compressor started but the fan didn't. However, I could take a stick and manually get the blades started in the right direction, whereupon the fan slowly spun up and is now operating normally. Of course the next cycle will likely blow that to smithereens...
(And yes, it is a residential single phase unit.)
Evstarr 08-09-2012 12:00 AM
Change the cap.
ben's plumbing 08-09-2012 07:04 PM
I second that change the capacitior...:yes:
