Condenser Fan Replacement Help - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2009, 06:10 PM   #1
I have a Carrier Puron Heat Pump Mode 38YZA036310.
I called an HVAC guy initially who diagnosed the condenser fan was bad and quoted me $1300+ to replace it. After seeing a few wires and four bolts plus a capacitor replacement was all that was entailed, I did it myself.
I replaced the GE 5kcp39gr motor with the Grainger recommended AO Smith Model F48U64A01. Specs were 1ph 208-230V 825rpm 1/5hp paired with a Dayton 2MDV4 capacitor.
This all worked out great for about a month, and last night we noticed it getting warm, and sure enough the stinking condenser fan is not running again. I checked voltage to make sure it was still good, checked the capacitor (I believe it is good...not sure I checked it right) turned my meter on ohms and watched it travel a bunch of numbers until it sat at 1. I then checked the resistance across the two hot wires and got a resistance reading of 1.3...which if I researched correctly is bad...not sure.
What the heck is killing my condensor motors? (If anyone has thoughts on additional ways to check it to confirm this it would be great)
Secondly, does it appear as though the linked motors will replace my current one(rpms are higher on the second one if that makes a difference?...or anyone elses suggestions would be most welcome.
http://www.aqua-man.com/motorManDeta...&motorID=11333
http://www.amazon.com/Diameter-Conde...7523620&sr=1-4
Thanks for your help!!!
Greg
jackofonetrade is offline   Reply With Quote
Old 07-13-2009, 06:35 PM   #2
HVAC / Plumbing
what is the cap putting out on c to fan ?? Was the cap rating the same as fan rating ?? Did you install a new cap.? Don't go over on the rpms
kenmac is offline   Reply With Quote
Old 07-13-2009, 06:47 PM   #3
The capacitor is the correct one...it was matched as per the manufacturer. It is rated at 370VAC. Thank you for your help.
Old 07-13-2009, 06:48 PM   #4
HVAC / Plumbing
The fan motor & cap. will have a uf rating
Old 07-13-2009, 06:56 PM   #5
5uf +/- 5%
Old 07-13-2009, 07:04 PM   #6
HVAC / Plumbing
could have just gotten bad motor... If I remember correctly. AO Smith are made in china land now
Old 07-13-2009, 07:07 PM   #7
Was the OEM fan wired into to a separate cap or did have other wires coming off it beside the fan motor?
hvaclover is offline   Reply With Quote
Old 07-13-2009, 07:24 PM   #8
was the fan turning in the right direction????
bervin306 is offline   Reply With Quote
Old 07-13-2009, 07:24 PM   #9
The original motor had a capacitor that had both the fan and compressor running into it. That capacitor is still being used by the compressor. The new motor has (or I guess had) a new capacitor and it is wired seperately just to the new motor.
Old 07-13-2009, 07:34 PM   #10
What do you mean "YOU GUESS'? Did you wire the new motor with the cap?
Also can you post a pic of the invoice that indicates the tech was going to charge you $1300.
Old 07-13-2009, 07:37 PM   #11
LOL...sorry It was my feeble attempt at humor...I meant that it was new along with the motor.
Old 07-13-2009, 07:43 PM   #12
The Carrier motor in the first link is rated for 60°C ambient, as it should be. What is the amb. temp. rating for the motor you put in?
Old 07-13-2009, 07:51 PM   #13
You wired in the cap wrong or the motor went bad .
And WHITEY, please! 1300 for condenser fan motor?
And you sittin' there wonderin' why ain't no body rushin' to answer 'yo Cracker butt.
Old 07-13-2009, 08:00 PM   #14
HVAC / Plumbing
Now, How do you know he's a cracker ??
Old 07-13-2009, 08:00 PM   #15
I will look and see if I still have it, but it was $1242 with thier "discounted membership plan" and that didn't even include tax! (Lowery Electric) I looked at the guy and said "You are kidding right?...dude it is four bolts and four wires....seriously?" The tech looked kind of sheepishly at me, and said...ummm yeah basically" I asked if they could just order me the motor...he said no they don't do that. I just shook my head as they were already 2 1/2hrs late for their "scheduled" appointment. I just couldn't
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 10:19 AM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 11:02 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
