Old 08-05-2012, 11:50 AM   #1
Condenser Fan Replacement
I am trying to replace my AC condener fan, but cannot get the old fan blades off the old fan motor due to corrosion. Any suggestions?
Ken928 is offline   Reply With Quote
Old 08-05-2012, 11:59 AM   #2
heat works well with a puller....tools make a world of difference...even then sometimes we ruin things...if its that bad cut both ends of shaft off heat it up drive it out .using drive rod .same size as shaft...picture would help
Old 08-05-2012, 12:20 PM   #3
biggles's Avatar
lock down screw is out...WD40 spray the hub and exposed shaft.take a channel locks and grab the shaft between the "motor and the blade" turn the hubfan blade area with your hand turn back and forth it will break loose....sand the exposed shaft above the blade so it can slide off.be careful with the blades on that fan if they get bent you'll have to get a new one....
The Following User Says Thank You to biggles For This Useful Post:
COLDIRON (08-05-2012)
Old 08-05-2012, 01:48 PM   #4
A gear puller and penetrating oil did the trick.
The Following User Says Thank You to Ken928 For This Useful Post:
ben's plumbing (08-05-2012)
Condenser fan motor and capacitor replacement topgun38 HVAC 5 07-18-2012 05:56 AM
Generator capacitor condenser replacement Bassmickster Electrical 0 08-25-2011 08:39 PM
Any ideas on a replacement condenser fan motor? 52Caddy HVAC 1 06-08-2011 10:30 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Condenser Fan Replacement Help jackofonetrade HVAC 20 07-13-2009 09:14 PM
