Old 05-17-2010, 07:28 PM   #1
Condenser Fan Motor Wiring
Hi Everyone.
I am trying to install a Dayton 4m205J motor(matched up by graingers) it is 1/4hp 208/230V.
It has 4 wires plus a green ground.
they are: Black, Brown, Brown/white, Purple
My old motor was Franklin Electric 1/8hp 208/230 V 3 wire: Brown, Red, Black.
I also have a new Start fan capacitor. (one side of the capacitor has a black wire hooked to it) This was also the side where the black wire on my old motor hooked into. The brown was on the opposite side. The red wire hooked into the contactor(I think thats what its called) with a larger guage red wire.
How do I wire this new motor? Thank you!
frito is offline   Reply With Quote
Old 05-17-2010, 08:30 PM   #2
Purple goes to the side of the contactor with the red wire from the compressor. Black goes to the other side of the contactor with the black compressor wire. The two browns go to the new capacitor.
Old 05-17-2010, 09:03 PM   #3
Thanks Marty
I have wired it as you explained.Which is how the diagram on the motor shows for a 4 wire setup. There is an optional 3 wire setup and wasn't sure if thats what I needed to follow?
I have a black wire hooked to my capacitor already(2 pole capacitor) - does it matter which brown wire connects to this side?
thanks!
Luke
Old 05-17-2010, 09:59 PM   #4
You'll remove that black wire from the new capacitor. Just put one brown lead on each capacitor terminal.
Old 05-17-2010, 10:12 PM   #5
An old Tradesmen
Look at the amp rating of your old motor, and your new motor.
The new motor, may not last long.
Old 05-17-2010, 10:32 PM   #6
old motor 1/8HP - 0.8 amps
New Dayton Motor 1/4 HP - 1.7-1.9 amps
Is this not reccomended for my system? the run capacitor is 5mf/370V
Old 05-18-2010, 04:07 AM   #7
hvaclover's Avatar
Dude your new motor is twice as powerful as your old !
It's gonna stress the hud to the point it fly to pieces!
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 05-18-2010, 06:23 AM   #8
An old Tradesmen
Good chance it may last a month.
The motor is going to want to work at its rated load. But won't be able to because the fan blades aren't going to be able to move enough air to put the motor under load. So the motor will over heat. Because it will over rev.
Take it back. And have them give you a motor that matches up to your old motors amp rating, and RPM.
Old 05-18-2010, 10:58 AM   #9
rpm on old motor - 1100 rpm
new motor rpm - 1075
would larger fan blades beof any use?
Old 05-18-2010, 11:11 AM   #10
I have it wired as marty explained. I grounded the green to chasis. The fan doesnt start and just hums. I dont think it is wired correctly. Anyone have any ideas?
Old 05-18-2010, 01:40 PM   #11
An old Tradesmen
Bigger blades would end up moving too much air through the condenser coil. And cause other troubles. Which could lead to compressor damage.
Do you have the black connected to the load of one side of the contactor, and the purple to the other load terminal of the contactor. Or did you by chance. Hook one wire to the load and one to the line of the same pole?
Do you have just 2 wires, the brown and the brown with white strip connected to the capacitor.
Can you post a pic of how its wired.
Old 05-18-2010, 08:01 PM   #12
Houston204's Avatar
If I understand you correctly, it was wired as shown in the 3 wire diagram (except red and black were switched) and you now have it wired as shown in the 4 wire diagram. Is this correct?
Houston204 is offline   Reply With Quote
Old 05-19-2010, 03:44 AM   #13
hvaclover's Avatar
Your diagrams are ok. But are you still going to put that larger motor on?
Old 05-19-2010, 11:44 PM   #14
Houston204's Avatar
While I doubt that the hub will fall apart in the next few years, I do not like installing larger motors because they will usually lower the fan blade in the condenser. This will cause higher head pressure. I've seen the air discharging from the upper portion of the condenser coil as opposed to the top of the unit more than a few times.
Old 06-22-2011, 09:25 PM   #15
Hi Everyone.
I am trying to install a Fasco D1050 motor
(matched up by http://acpartsdistributors.com/index...ducts_id=38354) it is 1/8hp 230V.
It has 2 wires plus a green ground.
they are: both Black
There appears to be a capacitor attached to the motor. One brown wire and one wire brown/white.
__________________________________
My old motor was Trane 322P807 1/8hp 3 wire: Gray, Blue, Black plus a green ground. No capacitor attached to the motor.
frankkool@yahoo.com
I am attaching 4 pictures, 2 of the old motor and 2 of the new motor.
frankkool is offline   Reply With Quote
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 11:09 AM
Condenser freezing zep HVAC 2 01-30-2010 09:04 PM
AC Condenser source of ignition? hrjrkr HVAC 4 09-16-2009 12:33 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 12:02 PM
