Condenser Fan Motor Running At Half Speed. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 09:09 PM   #1
Condenser fan motor running at half speed.
My condenser fan motor is running at half speed and my contactor is not engaged. When i start the unit up fan runs at full speed and compressor wont turn on. when i take the top off unit, compressor is smoking hot. Turn unit off and came back next day to let thermal reset and fire unit up and checked unit again smoking hot. replaced the capacitor and still the same issue. fan still runs half speed even when contactor not engaged and compressor wont run and hot to touch. any advise
jaxbeachman is offline   Reply With Quote
Old 08-31-2011, 09:15 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Did you check the run capacitor? Did you check continuity between motor windings?
You'll need a meter, preferrabley digital, that shows continuity/ohms. All you need is one that "beeps" when continuity is present.
With breaker off, remove the lid of the condenser and remove wiring harness or wires from the compressor itself. Test continuity from each of the three terminals to the other, start to common, common to run and run to start. Do this after the system has not been running for some hours to make sure that the thermal overload switch is not open as that would show no continuity due to an open common if it's overheated and has an open thermal protection switch.
If the compressor is cool and there is not continuity between any and all combinations of the terminals then the compressor is shot.
Doc Holliday is offline   Reply With Quote
Old 08-31-2011, 09:21 PM   #3
yea i replaced the capacitor first thing today since it was a cheap fix. But still samething is going on. Gonna check for continuity tomorrow dont feel like messing with it right now plus its dark out lol. But thanks for the advise i was a bit boggled . Will update tomorrow with what i find out. Thanks
Old 08-31-2011, 09:29 PM   #4
No problem. Please send check or money order to:
Sir Preston Aire c/o Roadhouse Mechanical Industries, Inc.
Technical Internet Services Department
Beverly Hills, Texas 90210
Old 08-31-2011, 09:55 PM   #5
An old Tradesmen
Rewards Points: 6,958
Sounds like a partial short to ground in the compressor. Could also be a shorted out crank case heater.
Old 09-01-2011, 10:35 PM   #6
soo..
Old 09-02-2011, 05:19 PM   #7
well after all it was a blow out terminal on compressor. Condenser is a 11yrs old so time for a new one i guess. Sorry i didnt get back sooner been really busy. Oh doc holiday your checks in the mail let me know when you get it.
Thanks guys
The Following User Says Thank You to jaxbeachman For This Useful Post:
Doc Holliday (09-02-2011)
Old 09-02-2011, 09:13 PM   #8
Thanks guys
Thanks. I'll be sending my kids to college with your payment.
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Variable Speed Vs " Multi - Speed " alecmcmahon HVAC 15 04-14-2011 03:06 PM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 07:18 AM
changing speed of grinder MeanGene Electrical 2 03-19-2011 09:53 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
